소개
This guide shows how to replace the rotor inside a Clarke Floor Buffer 01278A 2016.
You can use regular hand tools for removing fasteners, but using an impact driver will make the procedure easier.
필요한 것
Brace the back of the floor buffer with your foot near the wheel axle and grasp the handle with both hands.
Slowly tilt the floor buffer back until the handle rests on your work surface.
Use a 3/16" hex key or driver bit to remove the four 18.6 mm-long screws securing the shield brush to the bottom of the floor buffer.
Remove the eight 23.1 mm-long Phillips #3 screws securing the gear unit assembly and rotor to the floor buffer's housing.
Rest the center threaded bolt of a gear puller on the center of the rotor's driveshaft.
Attach the legs of the gear puller to the outer bottom edges of the bearing, and tighten the bolt by hand until the gear puller is snug on the bearing.
다른 16명이 해당 안내서를 완성하였습니다.
