주요 콘텐츠로 건너뛰기
Classic Ripstik Caster Board Wheels Replacement
필요한 것
  1. Classic Ripstik Caster Board Wheels Replacement, Wheels: 1 단계, 이미지 3개 중 1개 Classic Ripstik Caster Board Wheels Replacement, Wheels: 1 단계, 이미지 3개 중 2개 Classic Ripstik Caster Board Wheels Replacement, Wheels: 1 단계, 이미지 3개 중 3개
    • Use 2 5mm Allen Wrenches on both sides of the wheels and rotate both wrenches counterclockwise to take out the wheel, axle bolt, screw bolt, and 2 washers.
  2. Classic Ripstik Caster Board Wheels Replacement: 2 단계, 이미지 3개 중 1개 Classic Ripstik Caster Board Wheels Replacement: 2 단계, 이미지 3개 중 2개 Classic Ripstik Caster Board Wheels Replacement: 2 단계, 이미지 3개 중 3개
    • Take off the screw bolt on one end and the axle bolt on the other end.
    • Once you disassemble, make sure to save the bolts and washers in a safe place. You will use them for the new wheels.
  3. Classic Ripstik Caster Board Wheels Replacement: 3 단계, 이미지 2개 중 1개 Classic Ripstik Caster Board Wheels Replacement: 3 단계, 이미지 2개 중 2개
    • Slide the axle bolt through the hole on the outside and place the washer on the inside.
  4. Classic Ripstik Caster Board Wheels Replacement: 4 단계, 이미지 2개 중 1개 Classic Ripstik Caster Board Wheels Replacement: 4 단계, 이미지 2개 중 2개
    • Slide the axle bolt out just enough to place the wheel in the middle.
    • Slide the axle bolt through the middle of the wheel to hold the wheel in place.
    • It is easier to slide the bolt through the wheel if the wheel is being placed sideways.
  5. Classic Ripstik Caster Board Wheels Replacement: 5 단계, 이미지 2개 중 1개 Classic Ripstik Caster Board Wheels Replacement: 5 단계, 이미지 2개 중 2개
    • Place the second washer in between the wheel and the caster wall.
  6. Classic Ripstik Caster Board Wheels Replacement: 6 단계, 이미지 2개 중 1개 Classic Ripstik Caster Board Wheels Replacement: 6 단계, 이미지 2개 중 2개
    • Insert the screw bolt through the outside of the caster wall to go through the washer and the wheel.
  7. Classic Ripstik Caster Board Wheels Replacement: 7 단계, 이미지 3개 중 1개 Classic Ripstik Caster Board Wheels Replacement: 7 단계, 이미지 3개 중 2개 Classic Ripstik Caster Board Wheels Replacement: 7 단계, 이미지 3개 중 3개
    • Much like step 1, use 2 allen wrenches to screw in the wheel and secure it in place.
    • When screwing it, it is easier to hold one hand firm while rotating the other wrench clockwise to tighten.
결론
To replace your old RipStik wheels with brand new ones. Simply follow these steps and enjoy a brand-new ride!
작성자
1다른 기여자 명과 함께
JairoSantos
회원 가입일: 04/03/23
195 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 31
전체 시간: 1,080
