주요 콘텐츠로 건너뛰기
Clean Lookah 710 Wax Coils
필요한 것
  1. Clean Lookah 710 Wax Coils, Remove the coil: 1 단계, 이미지 1개 중 1개
    • Remove the coil: Take the coil out of your device.
    • The coils will unscrew counter clockwise.
  2. Clean Lookah 710 Wax Coils: 2 단계, 이미지 1개 중 1개
    • Wipe off excess: Use a Q-tip and a little isopropyl to wipe off any excess wax inside the coil. Wipe around the walls and mop up any excess wax. Use a tissue and a little isopropyl to wipe down the outside of the coil.
  3. Clean Lookah 710 Wax Coils: 3 단계, 이미지 1개 중 1개
    • Soak it: Place the coil in a bowl of cleaning alcohol (90% Isopropyl alcohol) for 30 minutes.
  4. Clean Lookah 710 Wax Coils: 4 단계, 이미지 2개 중 1개 Clean Lookah 710 Wax Coils: 4 단계, 이미지 2개 중 2개
    • Wipe outside: Remove the coil from the alcohol. Wipe off any alcohol around the outside of the coil. Wipe inside: Use a Q-tip and clean the inside of the coil gently. Don't press down on the quartz plate, which could damage it.
  5. Clean Lookah 710 Wax Coils: 5 단계, 이미지 1개 중 1개
    • Let it dry: Let the coil dry completely. This could take a few hours.
  6. Clean Lookah 710 Wax Coils: 6 단계, 이미지 1개 중 1개
    • Heat the Coil: Screw the coil back onto the Lookah vape, turn on the vape (5 clicks). Set the voltage to the highest setting. Then heat the coil 3 or 4 times. This will burn off the excess residue from the coil
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
James Mash
회원 가입일: 10/09/23
490 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 38
지난 30일: 157
전체 시간: 4,954
