소개
The coffee spout is a part that is rarely cleaned and is not cleaned efficiently by the cleaning program.
This guide will show you how to easily disassemble and manually clean it.
These instructions may also help with other Siemens/Bosch models — they have a very similar design.
필요한 것
Now slide the spudger/screwdriver between the plastic cap and the cover and gently pry in the direction of the coffee machine. This pushes the cover over the barb.
Grab the cover by the sides and pull it up. This is often very difficult, so pull it hard but not excessively.
Work through the steps in reverse order to reassemble your device.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
