필요한 것
Open the tray by pressing the eject button
Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
Locate the white clip that attaches the cord to the motherboard
Grasp clip and squeeze to release
Lift up and remove power cord
Slide cord mount from outer case
Spin small gear shown right to begin opening the tray. There should be relatively little resistance in the gear.
다른 14명이 해당 안내서를 완성하였습니다.
댓글 4개
Thank you Mitchell for your clear, concise directions and photos. I was able to dismantle my Samsung DVD-VCR player Model DVD-V2000. It recently quit playing DVD’s, showing a “No Disc” message. It will play CD’s just fine. I cleaned the laser and reinstalled but still no DVD, just CD’s will play. I like the machine and may look into a replacement DVD assembly if I can find one for a reasonable price. Otherwise I’ll upgrade to a new combo unit with the latest bells and whistles. Best wishes, Bill
I successfully fixed the "No Disc" issue on a DVD/VCR model DVD-V5000. Your guide helped and it was basically the same process. I used a foam tip (well a makeup applicator to be more precise) instead of a cotton tip, because it is less likely to leave anything behind like cotton strands. All works now, thanks!
Hello Mitchell,
Can I use this procedure to clean the laser of a Samsung D530 dvd player?…..mine also does it’s own thing and generally doesn’t respond to command same as the other users .
Thank you
Brian
Hello Mitchell, i tried this procedure on an LG 8600c DVD player, basically same procedure and managed to get to lens cleaned it and reassembled everything but now DVD tray doesn’t want to come out and obviously I get the NO DISK message as I cannot load and DVDs. Can you help please ?
Very Super service!
SzibeL - 답글
