주요 콘텐츠로 건너뛰기
ClickN Kids Tablet Touch Screen Display Replacement
필요한 것
  1. ClickN Kids Tablet Touch Screen Display Replacement, Touch Screen Display: 1 단계, 이미지 1개 중 1개
    • Start on the side with the camera. The screen side is black, the back side is colored
    • Insert a plastic opening tool into the space between the screen and the back side.
  2. ClickN Kids Tablet Touch Screen Display Replacement: 2 단계, 이미지 1개 중 1개
    • Press the plastic opening tool in until you hear a “click” and that part of the tablet opens.
    • Press and slide the plastic opening tool around all sides of the tablet until all sides pop off.
  3. ClickN Kids Tablet Touch Screen Display Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the detached screen from the camera side until you can see the inside of the tablet.
    • Potential for device damage. Don't open too fast, or you might damage the ribbon cables.
  4. ClickN Kids Tablet Touch Screen Display Replacement: 4 단계, 이미지 2개 중 1개 ClickN Kids Tablet Touch Screen Display Replacement: 4 단계, 이미지 2개 중 2개
    • Potential for device damage. Be careful not to damage any wires or ribbon cables during this step.
    • There are two ribbon cables to remove during this step. Each is connected to a base on the motherboard.
    • There is a black tab behind the long ribbon cable. Lift up the black tab.
    • For the ribbon cable in the back, pull the black tabs on the side out.
    • Detach the ribbon cables connecting the screen to the motherboard.
    • Remove any tape that is holding down the ribbon cables. Set it aside.
    • Once the ribbon cables are freed, separate the top and bottom sides.
  5. ClickN Kids Tablet Touch Screen Display Replacement: 5 단계, 이미지 2개 중 1개 ClickN Kids Tablet Touch Screen Display Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the yellow tape on the right side. Easiest side to get.
    • Remove the black and yellow tape stuck together on the left and bottom sides of the screen.
  6. ClickN Kids Tablet Touch Screen Display Replacement: 6 단계, 이미지 1개 중 1개
    • Potential for device damage. Make sure the screen is facedown and level to prevent or reduce damage to the display.
    • Potential for device damage. There is an adhesive on the top edge of the display’s face. Be careful not to damage the display.
    • Flex the sides of the tablet until the clips holding the display to the screen case pop loose.
  7. ClickN Kids Tablet Touch Screen Display Replacement: 7 단계, 이미지 2개 중 1개 ClickN Kids Tablet Touch Screen Display Replacement: 7 단계, 이미지 2개 중 2개
    • Be careful not to damage the display or screen case.
    • Pull the display from the top side to detach it from the screen case.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Kevin Finney
회원 가입일: 03/22/15
562 평판
안내서 4개를 작성함
Baylor, Team 4-4, Williams Spring 2015 Baylor, Team 4-4, Williams Spring 2015 회원
BU-WILLIAMS-S15S4G4
3 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 16
전체 시간: 8,147
