주요 콘텐츠로 건너뛰기
Closing bObi's Cover Post-Repair
필요한 것
  1. Closing bObi's Cover Post-Repair, Top Cover: 1 단계, 이미지 1/2 Closing bObi's Cover Post-Repair, Top Cover: 1 단계, 이미지 2/2
    • Remove bObi’s front wheel to access one of the screws holding bObi together.
    • Make sure the wheel is turned closer to bObi's front touch sensors. Use your screwdriver for leverage, and the wheel will pop up and out.
    • Uninstall the larger screw that sits deeper in the wheel compartment.
  2. Closing bObi's Cover Post-Repair: 2 단계, 이미지 1/3 Closing bObi's Cover Post-Repair: 2 단계, 이미지 2/3 Closing bObi's Cover Post-Repair: 2 단계, 이미지 3/3
    • Remove bObi's dustbin.
    • Uninstall the 2 screws close to the bin and 2 smaller screws above her main brushes.
  3. Closing bObi's Cover Post-Repair: 3 단계, 이미지 1/3 Closing bObi's Cover Post-Repair: 3 단계, 이미지 2/3 Closing bObi's Cover Post-Repair: 3 단계, 이미지 3/3
    • Lift the brush holder. To detach completely, unplug it from bObi.
    • Remove the two screws on the dustbin contact point holder inside bObi.
    • There are 4 screws beneath the main brushes. Uninstall these, and open bObi up to expose her main circuit board.
  4. Closing bObi's Cover Post-Repair: 4 단계, 이미지 1/3 Closing bObi's Cover Post-Repair: 4 단계, 이미지 2/3 Closing bObi's Cover Post-Repair: 4 단계, 이미지 3/3
    • Detach the two circuit plugs connecting bObi's cover to the main board and the cover will be completely removed.
  5. Closing bObi's Cover Post-Repair, Closing bObi's Cover Post-Repair: 5 단계, 이미지 1/1
    • Attach the circuit plugs from bObi's cover back on her main board.
    • The all white plug goes to the centre of the circuit board.
    • The smaller plug connects at the side, closer to bObi's left wheel.
  6. Closing bObi's Cover Post-Repair: 6 단계, 이미지 1/3 Closing bObi's Cover Post-Repair: 6 단계, 이미지 2/3 Closing bObi's Cover Post-Repair: 6 단계, 이미지 3/3
    • Lay down bObi's cover and line up the sides carefully.
    • Re-install the front wheel's screw.
    • Place the wheel back in its compartment so it points towards bObi's touch sensors. Push down to secure it on bObi.
    • Replace the dustbin contact point fastener on bObi and install its two screws.
  7. Closing bObi's Cover Post-Repair: 7 단계, 이미지 1/2 Closing bObi's Cover Post-Repair: 7 단계, 이미지 2/2
    • Install the four screws that were previously found under the main brushes.
    • Place the small main brush fastener overtop the screw posts on bObi and reinstall the two thin screws which hold it in place.
    • Lay the main brush attachment in the open space.
  8. Closing bObi's Cover Post-Repair: 8 단계, 이미지 1/2 Closing bObi's Cover Post-Repair: 8 단계, 이미지 2/2
    • Replace the corner pieces close to the dustbin and install the 2 screws securing them on bObi.
    • These corner pieces must line up correctly with the brush attachment and hold it in place.
    • Insert the dustbin before using bObi again.
결론
Follow this guide or reverse the directions of the Opening bObi guide to reassemble your device.
다른 2명이 해당 안내서를 완성하였습니다.
Chelsea
회원 가입일: 09/24/14
2,278 평판
안내서 31개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 4
전체 시간: 215
