주요 콘텐츠로 건너뛰기
Cloth Face Mask Nose Bridge Replacement
필요한 것
  1. Cloth Face Mask Nose Bridge Replacement, Nose Bridge: 1 단계, 이미지 2개 중 1개 Cloth Face Mask Nose Bridge Replacement, Nose Bridge: 1 단계, 이미지 2개 중 2개
    • It's best to wash your mask before and after handling to ensure cleanliness.
    • Lay the mask flat on desired surface.
    • Optional: Steam mask with a clothing iron to completely flatten and remove wrinkles.
    • Caution: Never leave the clothing iron unattended. Use caution when ironing as the machine will be hot to the touch.
    • Measure out the width of your face mask.
  2. Cloth Face Mask Nose Bridge Replacement: 2 단계, 이미지 2개 중 1개 Cloth Face Mask Nose Bridge Replacement: 2 단계, 이미지 2개 중 2개
    • Using a pen or pencil, mark the insertion point for the pipe cleaners.
    • A fabric pencil would be better suited for markings as it can be easily washed off.
  3. Cloth Face Mask Nose Bridge Replacement: 3 단계, 이미지 1개 중 1개
    • Seam rip where the elastic portion is. If there is no elastic present, then seam rip along the top portion of the mask.
    • Caution: Be mindful of where you place your fingers as it is possible to accidentally jab yourself with the seam ripper.
    • Consider using a thimble for protection.
  4. Cloth Face Mask Nose Bridge Replacement: 4 단계, 이미지 2개 중 1개 Cloth Face Mask Nose Bridge Replacement: 4 단계, 이미지 2개 중 2개
    • Cut a 4” strip of pipe cleaner.
    • Use caution when cutting pipe cleaners with scissors.
  5. Cloth Face Mask Nose Bridge Replacement: 5 단계, 이미지 1개 중 1개
    • Position the pipe cleaner where the markings are and fold the fabric over.
    • You may also use this as an opportunity to test out the positioning of the pipe cleaners before sewing the hem.
  6. Cloth Face Mask Nose Bridge Replacement: 6 단계, 이미지 1개 중 1개
    • Sew around the pipe cleaner using desired stitch.
    • A basic running stitch is recommended for ease.
    • Try on the mask to ensure the fit is right. Bend the pipe cleaners to best suit your facial frame.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Kayla Vargas
회원 가입일: 02/23/21
157 평판
안내서 1개를 작성함
Texas Tech, Team S3-G15, Cowan Spring 2021 Texas Tech, Team S3-G15, Cowan Spring 2021 회원
TTU-COWAN-S21S3G15
1 회원
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 15
전체 시간: 875
