소개
Let's suppose that one of your garments has lost a button. This would normally not be a matter of major concern, except for the fact that this particular button was not like other buttons: this button was sewn on with a ribbon. Luckily, a ribbon button such as yours can in fact be replaced, and this is how.
In this guide we are using contrasting thread for visibility. When it comes time to do your actual project, you will want to use thread and that matches the color of your ribbon.
If you don't have a sewing machine, you can still complete this guide by hand sewing.
For replacement parts or further assistance, contact Patagonia Customer Service.
필요한 것
Examine the garment where your ribbon button came off. There should be a little pocket where the ribbon came out.
Stitch rip the seam around the little pocket until it is large enough to easily slide the ribbon in.
Holding the ribbon in place, slide the garment into the sewing machine, aligning the presser foot with the place you want the button to sit.
Sew the ribbon in place.
Backstitch to hold the stitches in place.
Lift the presser foot and remove the garment from the sewing machine.
Clip any threads.
다른 한 분이 해당 안내서를 완성하였습니다.
