주요 콘텐츠로 건너뛰기
Cobra 29 LTD Classic Antenna Cable Replacement
  1. Cobra 29 LTD Classic Antenna Cable Replacement, Power Cable: 1 단계, 이미지 1/2 Cobra 29 LTD Classic Antenna Cable Replacement, Power Cable: 1 단계, 이미지 2/2
    • Turn the power switch, the leftmost knob, counterclockwise to off.
  2. Cobra 29 LTD Classic Antenna Cable Replacement: 2 단계, 이미지 1/2 Cobra 29 LTD Classic Antenna Cable Replacement: 2 단계, 이미지 2/2
    • Turn the device around and firmly pull the power cable plug to remove it from the radio.
  3. Cobra 29 LTD Classic Antenna Cable Replacement, Antenna Cable: 3 단계, 이미지 1/2 Cobra 29 LTD Classic Antenna Cable Replacement, Antenna Cable: 3 단계, 이미지 2/2
    • Unscrew the securing cap counterclockwise from the antenna connector.
  4. Cobra 29 LTD Classic Antenna Cable Replacement: 4 단계, 이미지 1/2 Cobra 29 LTD Classic Antenna Cable Replacement: 4 단계, 이미지 2/2
    • Gently pull the antenna cable to remove it from the back of the radio.
결론
danperoni
회원 가입일: 10/18/13
503 평판
안내서 4개 작성하였습니다
Cal Poly, Team 11-37, Amido Fall 2013 Cal Poly, Team 11-37, Amido Fall 2013 회원
CPSU-AMIDO-F13S11G37
4 회원들
안내서 9개 작성하였습니다
댓글 한 개
I dislike that kind of antenna plug. To easy to put together wrong. Better to find a pl259 plug that gets soldered. YouTube must have a video on it somewhere.
rrmanning06 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 22
전체 시간: 2,230
