소개
This outer cover is the main cover that protects the inner electrical components. Perform the guide on a flat non-conductive surface to avoid electrical shock and damage to your device.
필요한 것
Unscrew the cap counterclockwise on the microphone plug to disconnect the cable.
Unscrew the top four 6.0mm Phillips head screws counterclockwise on the left and right side of the device using a #1 Phillips head screwdriver.
다른 2명이 해당 안내서를 완성하였습니다.
