주요 콘텐츠로 건너뛰기
Coby DVD-R11000 Circuit Boards Replacement
필요한 것
  1. Coby DVD-R11000 Circuit Boards Replacement, Outer Casing: 1 단계, 이미지 1/3 Coby DVD-R11000 Circuit Boards Replacement, Outer Casing: 1 단계, 이미지 2/3 Coby DVD-R11000 Circuit Boards Replacement, Outer Casing: 1 단계, 이미지 3/3
    • Remove the four 1cm screws, two on each side, of the DVD player with the Phillips #1 screwdriver.
    • Remove the five 1cm screws on the back of the DVD player with the Phillips #1 screwdriver.
    • It is not required to remove the other seven screws in the middle between the I/O ports.
  2. Coby DVD-R11000 Circuit Boards Replacement: 2 단계, 이미지 1/3 Coby DVD-R11000 Circuit Boards Replacement: 2 단계, 이미지 2/3 Coby DVD-R11000 Circuit Boards Replacement: 2 단계, 이미지 3/3
    • Position the DVD player so that the back is facing you
    • Grab underneath the sides of the DVD player and lift the front of it upwards.
    • Carefully pull the top of the casing off
  3. Coby DVD-R11000 Circuit Boards Replacement, 3-Pin Power Cable: 3 단계, 이미지 1/2 Coby DVD-R11000 Circuit Boards Replacement, 3-Pin Power Cable: 3 단계, 이미지 2/2
    • Gently pinch the 3-pin white adapter of the wire connecting the power cord to the circuit board.
    • Remove the wire from the circuit board.
  4. Coby DVD-R11000 Circuit Boards Replacement, Circuit Boards: 4 단계, 이미지 1/2 Coby DVD-R11000 Circuit Boards Replacement, Circuit Boards: 4 단계, 이미지 2/2
    • Position the DVD player so that the side with golden circuit board, where the power cord was plugged into, is closest to you.
    • Remove the black wire with the 6-pin white adapter, which is adjacent to the other three pin adapter wires on the golden circuit board.
  5. Coby DVD-R11000 Circuit Boards Replacement: 5 단계, 이미지 1/3 Coby DVD-R11000 Circuit Boards Replacement: 5 단계, 이미지 2/3 Coby DVD-R11000 Circuit Boards Replacement: 5 단계, 이미지 3/3
    • Position the DVD player so that the back panel is facing you.
    • Remove the three wires with the white pin adapters from the golden circuit board.
  6. Coby DVD-R11000 Circuit Boards Replacement: 6 단계, 이미지 1/3 Coby DVD-R11000 Circuit Boards Replacement: 6 단계, 이미지 2/3 Coby DVD-R11000 Circuit Boards Replacement: 6 단계, 이미지 3/3
    • Remove the four half inch screws, located at each corner of the golden circuit board, using the Phillips #1 screwdriver.
    • Place the blue plastic tool opener underneath the side of the circuit board and carefully remove it from the DVD player.
  7. Coby DVD-R11000 Circuit Boards Replacement: 7 단계, 이미지 1/3 Coby DVD-R11000 Circuit Boards Replacement: 7 단계, 이미지 2/3 Coby DVD-R11000 Circuit Boards Replacement: 7 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Position the DVD player so that the front is facing you.
    • Using the tweezers and the blue plastic opening tool, disconnect the ribbon cables from the green circuit board where the I/O ports are attach to.
  8. Coby DVD-R11000 Circuit Boards Replacement: 8 단계, 이미지 1/3 Coby DVD-R11000 Circuit Boards Replacement: 8 단계, 이미지 2/3 Coby DVD-R11000 Circuit Boards Replacement: 8 단계, 이미지 3/3
    • Remove the three wires with the white pin adapters from the green circuit board that you just disconnected the ribbon wires from.
  9. Coby DVD-R11000 Circuit Boards Replacement: 9 단계, 이미지 1/3 Coby DVD-R11000 Circuit Boards Replacement: 9 단계, 이미지 2/3 Coby DVD-R11000 Circuit Boards Replacement: 9 단계, 이미지 3/3
    • Remove the seven 1cm screws located on the back panel of the outer casing, in between the I/O ports, with the Phillips #1 screwdriver
    • Grab the sides of the back panel and remove it from the DVD player.
  10. Coby DVD-R11000 Circuit Boards Replacement: 10 단계, 이미지 1/2 Coby DVD-R11000 Circuit Boards Replacement: 10 단계, 이미지 2/2
    • Remove the two 1cm screws that are circled in red.
결론
Andrew
회원 가입일: 10/22/14
501 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 1-6, Shastany Fall 2014 UMass Dartmouth, Team 1-6, Shastany Fall 2014 회원
UMASSD-SHASTANY-F14S1G6
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 529
