주요 콘텐츠로 건너뛰기
Coby DVD209 4-Pin Ribbon Cable Replacement
필요한 것
  1. Coby DVD209 4-Pin Ribbon Cable Replacement, The bottom portion of the DVD player: 1 단계, 이미지 1/3 Coby DVD209 4-Pin Ribbon Cable Replacement, The bottom portion of the DVD player: 1 단계, 이미지 2/3 Coby DVD209 4-Pin Ribbon Cable Replacement, The bottom portion of the DVD player: 1 단계, 이미지 3/3
    • Press the eject button to view the laser inside.
    • Using the blue plastic tool and the tweezers, remove the ribbon cable.
  2. Coby DVD209 4-Pin Ribbon Cable Replacement: 2 단계, 이미지 1/3 Coby DVD209 4-Pin Ribbon Cable Replacement: 2 단계, 이미지 2/3 Coby DVD209 4-Pin Ribbon Cable Replacement: 2 단계, 이미지 3/3
    • Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
    • Do not lift the top of the DVD player too quickly because there are wires attached on the inside.
    • Pry the top of the device open from the right side where the buttons are located.
  3. Coby DVD209 4-Pin Ribbon Cable Replacement: 3 단계, 이미지 1/3 Coby DVD209 4-Pin Ribbon Cable Replacement: 3 단계, 이미지 2/3 Coby DVD209 4-Pin Ribbon Cable Replacement: 3 단계, 이미지 3/3
    • When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them.
    • Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
  4. Coby DVD209 4-Pin Ribbon Cable Replacement, 4-Pin Ribbon Cable: 4 단계, 이미지 1/3 Coby DVD209 4-Pin Ribbon Cable Replacement, 4-Pin Ribbon Cable: 4 단계, 이미지 2/3 Coby DVD209 4-Pin Ribbon Cable Replacement, 4-Pin Ribbon Cable: 4 단계, 이미지 3/3
    • Position the DVD player so that the power and AVI ports are facing you.
    • Pull the white cable with the blue adapters off of the circuit boards.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Yufay Chow
회원 가입일: 01/23/12
92 평판
안내서 4개 작성하였습니다
Cal Poly, Team 10-36, Amido Winter 2012 Cal Poly, Team 10-36, Amido Winter 2012 회원
CPSU-AMIDO-W12S10G36
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 1,007
