주요 콘텐츠로 건너뛰기
Coby DVD209 Circuit Board for Buttons Replacement
필요한 것
  1. Coby DVD209 Circuit Board for Buttons Replacement, The bottom portion of the DVD player: 1 단계, 이미지 3개 중 1개 Coby DVD209 Circuit Board for Buttons Replacement, The bottom portion of the DVD player: 1 단계, 이미지 3개 중 2개 Coby DVD209 Circuit Board for Buttons Replacement, The bottom portion of the DVD player: 1 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Press the eject button to view the laser inside.
    • Using the blue plastic tool and the tweezers, remove the ribbon cable.
  2. Coby DVD209 Circuit Board for Buttons Replacement: 2 단계, 이미지 3개 중 1개 Coby DVD209 Circuit Board for Buttons Replacement: 2 단계, 이미지 3개 중 2개 Coby DVD209 Circuit Board for Buttons Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
    • Do not lift the top of the DVD player too quickly because there are wires attached on the inside.
    • Pry the top of the device open from the right side where the buttons are located.
  3. Coby DVD209 Circuit Board for Buttons Replacement: 3 단계, 이미지 3개 중 1개 Coby DVD209 Circuit Board for Buttons Replacement: 3 단계, 이미지 3개 중 2개 Coby DVD209 Circuit Board for Buttons Replacement: 3 단계, 이미지 3개 중 3개
    • When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them.
    • Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
  4. Coby DVD209 Circuit Board for Buttons Replacement, Circuit Board for Buttons: 4 단계, 이미지 2개 중 1개 Coby DVD209 Circuit Board for Buttons Replacement, Circuit Board for Buttons: 4 단계, 이미지 2개 중 2개
    • Take the top portion of the DVD player and orient the device as shown in the first picture.
    • Remove the four 0.2" screws circled in red.
  5. Coby DVD209 Circuit Board for Buttons Replacement: 5 단계, 이미지 3개 중 1개 Coby DVD209 Circuit Board for Buttons Replacement: 5 단계, 이미지 3개 중 2개 Coby DVD209 Circuit Board for Buttons Replacement: 5 단계, 이미지 3개 중 3개
    • Losen the screw circled in red.
    • The screw will not come out of the plastic knob.
    • Turn the plastic knob 90 degrees to the right so that the cable comes out freely.
결론
작성자
7다른 기여자 명과 함께
Yufay Chow
회원 가입일: 01/23/12
92 평판
안내서 4개를 작성함
Cal Poly, Team 10-36, Amido Winter 2012 Cal Poly, Team 10-36, Amido Winter 2012 회원
CPSU-AMIDO-W12S10G36
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 550
