이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Is the screen of your device cracked and in need of replacement? This guide will walk you through the removal and replacement of your screen.
필요한 것
Use iFixit plastic opening tool to make small opening in the side of the device, and continue opening back panel.
There are 5 ribbon cables connected to the motherboard. Two of these cables are clipped on and one is soldered on. Remove the 4 ribbon cables you can clip off using the plastic spudger.
For large ribbon cable use plastic spudger or your fingers to release ribbon cable clip by pulling the black edges down and pulling ribbon cable out.
For ribbon cable on the left side, flip up black hinge to remove ribbon cable
Desolder fifth ribbon cable with soldering station.
Now that the digitizer is disconnected from the screen you can replace the screen.
Place the screen face down in front of you facing downward and apply pressure with your thumbs around the outside of the glass to remove the screen.
Next, replace with your new screen and follow steps in reverse order to reassemble.
