이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use iFixit plastic opening tool to make small opening in the side of the device, and continue opening back panel.
Locate battery. The battery is the silver coated square shaped device on the top of the motherboard.
There is a small ribbon cable located under the battery. running from the volume buttons underneath the batter to main logic board.
After the battery is free from the logic board, find the positive and negative wires that connect the battery to the motherboard
Using a soldering gun, heat up both soldering points.
Remove wires from logic board
Clean up soldering joints with a desoldering sucker
Solder the new battery wires to the same soldering points as the old battery
Reverse steps 1-5 to put device back together
다른 한 분이 해당 안내서를 완성하였습니다.
