주요 콘텐츠로 건너뛰기
Coby Kyros MID7125 Speaker Replacement
필요한 것
  1. Coby Kyros MID7125 Speaker Replacement, Speaker: 1 단계, 이미지 1/1
    • Use opening too to make small opening in the side of the device.
    • Use plastic opening tool to pry the rest of the panel off.
  2. Coby Kyros MID7125 Speaker Replacement: 2 단계, 이미지 1/1
    • Once inside the device, locate the speakers on the inside of the back panel.
  3. Coby Kyros MID7125 Speaker Replacement: 3 단계, 이미지 1/1
    • Use spudger to pry one speaker up off of the back panel.
  4. Coby Kyros MID7125 Speaker Replacement: 4 단계, 이미지 1/1
    • Desolder the soldering points that connect the speaker to the motherboard.
  5. Coby Kyros MID7125 Speaker Replacement: 5 단계, 이미지 1/1
    • Use a soldering iron to solder the wires of the new speaker to the motherboard.
    • Make sure, when soldering, to connect the red wire to the red and the black wire to the black.
  6. Coby Kyros MID7125 Speaker Replacement: 6 단계, 이미지 1/1
    • Click the new speaker into the spot where you removed the old speaker.
    • Follow steps 2-6 for the other speaker. Snap in back panel to put device back together.
결론
Nicole Connelly
회원 가입일: 10/20/16
1 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 5-2, Martin Fall 2016 UMass Dartmouth, Team 5-2, Martin Fall 2016 회원
UMASSD-MARTIN-F16S5G2
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 132
