주요 콘텐츠로 건너뛰기
Coby Kyros MID7125 Speaker Replacement
필요한 것
  1. Coby Kyros MID7125 Speaker Replacement, Speaker: 1 단계, 이미지 1개 중 1개
    • Use opening too to make small opening in the side of the device.
    • Use plastic opening tool to pry the rest of the panel off.
  2. Coby Kyros MID7125 Speaker Replacement: 2 단계, 이미지 1개 중 1개
    • Once inside the device, locate the speakers on the inside of the back panel.
  3. Coby Kyros MID7125 Speaker Replacement: 3 단계, 이미지 1개 중 1개
    • Use spudger to pry one speaker up off of the back panel.
  4. Coby Kyros MID7125 Speaker Replacement: 4 단계, 이미지 1개 중 1개
    • Desolder the soldering points that connect the speaker to the motherboard.
  5. Coby Kyros MID7125 Speaker Replacement: 5 단계, 이미지 1개 중 1개
    • Use a soldering iron to solder the wires of the new speaker to the motherboard.
    • Make sure, when soldering, to connect the red wire to the red and the black wire to the black.
  6. Coby Kyros MID7125 Speaker Replacement: 6 단계, 이미지 1개 중 1개
    • Click the new speaker into the spot where you removed the old speaker.
    • Follow steps 2-6 for the other speaker. Snap in back panel to put device back together.
결론
작성자
3다른 기여자 명과 함께
Nicole Connelly
회원 가입일: 10/20/16
1 평판
안내서 3개를 작성함
UMass Dartmouth, Team 5-2, Martin Fall 2016 UMass Dartmouth, Team 5-2, Martin Fall 2016 회원
UMASSD-MARTIN-F16S5G2
3 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 5
전체 시간: 158
