이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use opening too to make small opening in the side of the device.
Use plastic opening tool to pry the rest of the panel off.
Once inside the device, locate the speakers on the inside of the back panel.
Desolder the soldering points that connect the speaker to the motherboard.
Use a soldering iron to solder the wires of the new speaker to the motherboard.
Click the new speaker into the spot where you removed the old speaker.
Follow steps 2-6 for the other speaker. Snap in back panel to put device back together.
