주요 콘텐츠로 건너뛰기
Coby Kyros MID9042 Battery Replacement
필요한 것
  1. Coby Kyros MID9042 Battery Replacement, Battery: 1 단계, 이미지 1/3 Coby Kyros MID9042 Battery Replacement, Battery: 1 단계, 이미지 2/3 Coby Kyros MID9042 Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Before taking the tablet apart, power off the device.
    • Remove anti-slip pads from all four corners of the back of the device with a nylon spudger.
    • Remove the four 1/8" screws using a Phillips #0 screwdriver.
  2. Coby Kyros MID9042 Battery Replacement: 2 단계, 이미지 1/3 Coby Kyros MID9042 Battery Replacement: 2 단계, 이미지 2/3 Coby Kyros MID9042 Battery Replacement: 2 단계, 이미지 3/3
    • Potential for device damage: Be careful not to break the inner plastic tabs while pulling the back cover off.
    • Use an opening tool to wedge the back cover apart from the front.
    • Once the edges are wedged apart, use your hands to remove the back of the tablet.
  3. Coby Kyros MID9042 Battery Replacement: 3 단계, 이미지 1/3 Coby Kyros MID9042 Battery Replacement: 3 단계, 이미지 2/3 Coby Kyros MID9042 Battery Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • With the soldering iron, desolder the red and black battery wires from the circuit board.
    • Use the tweezers to connect the red wire to the positive and the black wire to the negative.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Samantha Rollings
회원 가입일: 03/30/15
349 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 2-6, Shastany Spring 2015 UMass Dartmouth, Team 2-6, Shastany Spring 2015 회원
UMASSD-SHASTANY-S15S2G6
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 9
전체 시간: 1,091
