주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
  1. Use a spudger to remove the four rubber screw covers from the four back corners of the tablet.
    • Use a spudger to remove the four rubber screw covers from the four back corners of the tablet.
  2. Place the PH00 screwdriver and use it to remove the four 0.5 cm screws from each corner of the tablet.
    • Place the PH00 screwdriver and use it to remove the four 0.5 cm screws from each corner of the tablet.
  3. Place a metal spudger tool in between the front and back panels of the tablet and begin to pry the base from the front panel by moving the metal tool around the perimeter of the tablet.
    • Place a metal spudger tool in between the front and back panels of the tablet and begin to pry the base from the front panel by moving the metal tool around the perimeter of the tablet.
    • Note that clicking noises will be heard during this process, the panels are assembled well so it may take some force to separate the two panels.
    • Use caution while prying, do not stick the metal spudger in too far as it may damage internal components
  4. Use a soldering iron to remove the connection between the red wire first then proceed to the black wire.
    • Use a soldering iron to remove the connection between the red wire first then proceed to the black wire.
결론
Ian Swett
회원 가입일: 2015년 03월 11일
597 평판
안내서 5개 작성하였습니다
Colorado Springs, Team 5-3, Panko Spring 2015 Colorado Springs, Team 5-3, Panko Spring 2015 회원
UCCS-PANKO-S15S5G3
3 회원들
안내서 12개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 648
