필요한 것
Use a spudger to remove the four rubber screw covers from the four back corners of the tablet.
Using the PH00 screwdriver unscrew and rotate the plastic tabs that are holding the screen in place.
Gently pull on the black tab connecting the ribbon cable to the back of the tablet.
Remove ribbon cable from port to free the digitizer.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
