소개
This process is easy, but will require some soldering.
필요한 것
Use a spudger to remove the four rubber screw covers from the four back corners of the tablet.
Use a soldering iron to remove the connection between the red wire first then proceed to the black wire.
Use the PH00 screwdriver to remove the six 0.25 cm screws circled in the image.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
