소개
This process is easy, but will require some soldering.
필요한 것
Use a spudger to remove the four rubber screw covers from the four back corners of the tablet.
Use a soldering iron to remove the connection between the red wire first then proceed to the black wire.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
