필요한 것
Use a spudger to remove the four rubber screw covers from the four back corners of the tablet.
Using the PH00 screwdriver unscrew and rotate the plastic tabs that are holding the screen in place.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
댓글 3개
Is the flex cable detachable from the LCD
Do u have the display flex cable
