주요 콘텐츠로 건너뛰기
Coin Display Case Glass Attachment
필요한 것
  1. Coin Display Case Glass Attachment, Coin Display Case Glass Attachment: 1 단계, 이미지 2개 중 1개 Coin Display Case Glass Attachment, Coin Display Case Glass Attachment: 1 단계, 이미지 2개 중 2개
    • Clean the display case thoroughly with glass cleaner and a paper towel.
  2. Coin Display Case Glass Attachment: 2 단계, 이미지 1개 중 1개
    • Gently pry the glass away from the glue on the frame. Be careful not to shatter the glass.
  3. Coin Display Case Glass Attachment: 3 단계, 이미지 1개 중 1개
    • Apply a thin, solid line of a strong adhesive, such as Gorilla Glue, to the entire inner border of the display case where the glass attaches.
  4. Coin Display Case Glass Attachment: 4 단계, 이미지 2개 중 1개 Coin Display Case Glass Attachment: 4 단계, 이미지 2개 중 2개
    • Gently, but firmly, press the glass back into the felt lining. Run your finger with firm pressure along the entire lining of the glass two times.
  5. Coin Display Case Glass Attachment: 5 단계, 이미지 1개 중 1개
    • Allow the glue to set for 2-4 hours for the strongest bond.
    • Keep the case in the upright position while the glue sets.
    • Do not close or shut the case during the drying/setting process.
결론
Allow the glass and glue to bond for at least 6 hours before using the case.
작성자
12다른 기여자 명과 함께
Jesse Norris
회원 가입일: 02/08/16
113 평판
안내서 1개를 작성함
Pasco Hernando, Team 5-2, Prince Winter 2016 Pasco Hernando, Team 5-2, Prince Winter 2016 회원
PHSC-PRINCE-W16S5G2
1 회원
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 15
전체 시간: 1,308
