주요 콘텐츠로 건너뛰기
ColecoVision Motherboard Replacement
필요한 것
  1. ColecoVision Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Start by laying the console face down.
    • Remove the eight 15mm Phillips #1 screws from the bottom of the device.
  2. ColecoVision Motherboard Replacement: 2 단계, 이미지 1/2 ColecoVision Motherboard Replacement: 2 단계, 이미지 2/2
    • Flip the console back over.
    • Lift the front panel off. I would reccomended using a metal spudger along the rim of the top to safely remove it and set it aside.
  3. ColecoVision Motherboard Replacement: 3 단계, 이미지 1/2 ColecoVision Motherboard Replacement: 3 단계, 이미지 2/2
    • Remove the two 15mm Phillips #1 screws holding the casing in place.
    • Carefully lift the casing from the motherboard.
  4. ColecoVision Motherboard Replacement: 4 단계, 이미지 1/1
    • Remove the center Phillips #1 screw near the cartridge slot.
    • Remove the second Phillips #1 screw near the RAM chips.
    • Carefully lift and remove the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Krystalina
회원 가입일: 10/24/18
121 평판
안내서 1개 작성함
UW Tacoma, Team S1-G2, Rose Fall 2018 UW Tacoma, Team S1-G2, Rose Fall 2018 회원
UWT-ROSE-F18S1G2
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 26
전체 시간: 1,580
