이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Start by laying the console face down.
Remove the eight 15mm Phillips #1 screws from the bottom of the device.
Flip the console back over.
Lift the front panel off. I would reccomended using a metal spudger along the rim of the top to safely remove it and set it aside.
Remove the two 15mm Phillips #1 screws holding the casing in place.
Carefully lift the casing from the motherboard.
Remove the center Phillips #1 screw near the cartridge slot.
Remove the second Phillips #1 screw near the RAM chips.
Carefully lift and remove the motherboard.
다른 한 분이 해당 안내서를 완성하였습니다.
