소개
Power not reaching your motherboard? Does the lantern not illuminate even though its been charged? Check out this guide on how to remove and replace the battery!
필요한 것
Carefully turn the lantern upside down.
Remove the three 1.2 mm Phillips #0 screws from the base of the lantern.
댓글 한 개
Sean, I’m facing a dead battery in my Coleman twin tube fluorescent lantern also. Your directions are spot on except my battery seems to be glued in with super glue! I’ve tried a heat gun and all my strength but my battery won’t come loose. I find it hard to pry under the battery because of the shape of the plastic partitions around the battery. How did you get the battery unstuck?
BilMcKelvy - 답글
