주요 콘텐츠로 건너뛰기
Coleman Rechargeable Fluorescent Twin Tube Battery Replacement
필요한 것
  1. Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement, Battery: 1 단계, 이미지 1/2 Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement, Battery: 1 단계, 이미지 2/2
    • Carefully turn the lantern upside down.
    • Remove the three 1.2 mm Phillips #0 screws from the base of the lantern.
  2. Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: 2 단계, 이미지 1/1
    • Carefully pull the bottom of the lantern to remove the base from the device.
  3. Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: 3 단계, 이미지 1/2 Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: 3 단계, 이미지 2/2
    • Gently pull the battery out of the slot and away from the base.
    • The battery may be held into place by adhesive strips.
  4. Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: 4 단계, 이미지 1/3 Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: 4 단계, 이미지 2/3 Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: 4 단계, 이미지 3/3
    • Carefully detach the negative wire from the battery terminal first.
    • Next, detach the positive wire from the battery terminal.
결론
Sean
회원 가입일: 09/17/18
265 평판
안내서 2개 작성하였습니다
Washington State, Team S2-G1, Hope Fall 2018 Washington State, Team S2-G1, Hope Fall 2018 회원
WSU-HOPE-F18S2G1
4 회원들
안내서 8개 작성하였습니다
댓글 한 개
Sean, I’m facing a dead battery in my Coleman twin tube fluorescent lantern also. Your directions are spot on except my battery seems to be glued in with super glue! I’ve tried a heat gun and all my strength but my battery won’t come loose. I find it hard to pry under the battery because of the shape of the plastic partitions around the battery. How did you get the battery unstuck?
BilMcKelvy - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 23
30일 전: 85
전체 시간: 4,605
