메인 콘텐츠로 스킵하기
소개
Is your switch unable to move due to a foreign liquid? Does the switch feel like its seated improperly? Check out this guide on removing and replacing the switch.
  1. Carefully turn the lantern upside down. Remove the three 1.2 mm Phillips #0 screws from the base of the lantern.
    • Carefully turn the lantern upside down.
    • Remove the three 1.2 mm Phillips #0 screws from the base of the lantern.
  2. Carefully pull the bottom of the lantern to remove the base from the device.
    • Carefully pull the bottom of the lantern to remove the base from the device.
  3. Gently pull the battery out of the slot and away from the base. The battery may be held into place by adhesive strips.
    • Gently pull the battery out of the slot and away from the base.
    • The battery may be held into place by adhesive strips.
  4. Carefully detach  the negative wire from the battery terminal first. Next, detach the positive wire from the battery terminal. Next, detach the positive wire from the battery terminal.
    • Carefully detach the negative wire from the battery terminal first.
    • Next, detach the positive wire from the battery terminal.
  5. Remove the single 1.2 mm Phillips #1 screw on the bottom of the lantern. Remove the plastic barrier.
    • Remove the single 1.2 mm Phillips #1 screw on the bottom of the lantern.
    • Remove the plastic barrier.
  6. Unscrew the single 1.2 mm Phillips #1 screw holding the motherboard to the plastic lantern housing. Unscrew the single 1.2 mm Phillips #1 screw holding the motherboard to the plastic lantern housing.
    • Unscrew the single 1.2 mm Phillips #1 screw holding the motherboard to the plastic lantern housing.
  7. Gently grab the main board by the exposed PCB. Pull the main board straight out of the housing. Pull the main board straight out of the housing.
    • Gently grab the main board by the exposed PCB.
    • Pull the main board straight out of the housing.
  8. Remove the switch by pushing down on the ends while simultaneously pulling it out of the slot. When removing the switch, make sure to depress the inner clips when removing from the device. Be careful, do not force the switch from the base of the lantern.
    • Remove the switch by pushing down on the ends while simultaneously pulling it out of the slot.
    • When removing the switch, make sure to depress the inner clips when removing from the device. Be careful, do not force the switch from the base of the lantern.
결론
Mathew Merrick
회원 가입일: 2018년 09월 17일
169 평판
안내서 2개 작성하였습니다
Washington State, Team S2-G1, Hope Fall 2018 Washington State, Team S2-G1, Hope Fall 2018 회원
WSU-HOPE-F18S2G1
4 회원들
안내서 4개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 46
