소개
Have you troubleshooted everything else and nothing is working to fix the device? Replacing the main power board might be your last resort.
필요한 것
Carefully turn the lantern upside down.
Remove the three 1.2 mm Phillips #0 screws from the base of the lantern.
Remove the single 1.2 mm Phillips #1 screw on the bottom of the lantern.
Remove the plastic barrier.
거의 끝나갑니다!
결론
