주요 콘텐츠로 건너뛰기
ComNet Ericsson Panther 600P Display Replacement
필요한 것
  1. ComNet Ericsson Panther 600P Display Replacement, Locate the release button.: 1 단계, 이미지 1/3 ComNet Ericsson Panther 600P Display Replacement, Locate the release button.: 1 단계, 이미지 2/3 ComNet Ericsson Panther 600P Display Replacement, Locate the release button.: 1 단계, 이미지 3/3
    • Look for the release button on the back of the radio.
    • Press the button and pull down on the battery at the same time. The battery will come free.
  2. ComNet Ericsson Panther 600P Display Replacement, Antenna: 2 단계, 이미지 1/1
    • Twist the antenna counter-clockwise to unscrew it from the antenna jack.
  3. ComNet Ericsson Panther 600P Display Replacement, Dials: 3 단계, 이미지 1/1
    • Pull up on the dials to remove them from the underlying pegs.
  4. ComNet Ericsson Panther 600P Display Replacement, Exterior Case: 4 단계, 이미지 1/3 ComNet Ericsson Panther 600P Display Replacement, Exterior Case: 4 단계, 이미지 2/3 ComNet Ericsson Panther 600P Display Replacement, Exterior Case: 4 단계, 이미지 3/3
    • Using a T15 Torx screwdriver, unscrew the two screws.
    • Using a plastic opening tool, pry the internal case from the external case.
  5. ComNet Ericsson Panther 600P Display Replacement, Front Case - Internal: 5 단계, 이미지 1/3 ComNet Ericsson Panther 600P Display Replacement, Front Case - Internal: 5 단계, 이미지 2/3 ComNet Ericsson Panther 600P Display Replacement, Front Case - Internal: 5 단계, 이미지 3/3
    • Using the plastic opening tool, pry the case apart.
  6. ComNet Ericsson Panther 600P Display Replacement, Ribbon: 6 단계, 이미지 1/2 ComNet Ericsson Panther 600P Display Replacement, Ribbon: 6 단계, 이미지 2/2
    • The keypad chip is attached to the motherboard by a ribbon.
    • Pull ribbon with tweezers to detach from back panel.
  7. ComNet Ericsson Panther 600P Display Replacement, Screen: 7 단계, 이미지 1/3 ComNet Ericsson Panther 600P Display Replacement, Screen: 7 단계, 이미지 2/3 ComNet Ericsson Panther 600P Display Replacement, Screen: 7 단계, 이미지 3/3
    • Screen will be attached by a ribbon.
    • Pull screen up and away from motherboard to detach.
결론
Daniel
회원 가입일: 01/13/15
109 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 209
