주요 콘텐츠로 건너뛰기
ComNet Ericsson Panther 600P Speaker Replacement
필요한 것
  1. ComNet Ericsson Panther 600P Speaker Replacement, Locate the release button.: 1 단계, 이미지 1/3 ComNet Ericsson Panther 600P Speaker Replacement, Locate the release button.: 1 단계, 이미지 2/3 ComNet Ericsson Panther 600P Speaker Replacement, Locate the release button.: 1 단계, 이미지 3/3
    • Look for the release button on the back of the radio.
    • Press the button and pull down on the battery at the same time. The battery will come free.
  2. ComNet Ericsson Panther 600P Speaker Replacement, Antenna: 2 단계, 이미지 1/1
    • Twist the antenna counter-clockwise to unscrew it from the antenna jack.
  3. ComNet Ericsson Panther 600P Speaker Replacement, Dials: 3 단계, 이미지 1/1
    • Pull up on the dials to remove them from the underlying pegs.
  4. ComNet Ericsson Panther 600P Speaker Replacement, Exterior Case: 4 단계, 이미지 1/3 ComNet Ericsson Panther 600P Speaker Replacement, Exterior Case: 4 단계, 이미지 2/3 ComNet Ericsson Panther 600P Speaker Replacement, Exterior Case: 4 단계, 이미지 3/3
    • Using a T15 Torx screwdriver, unscrew the two screws.
    • Using a plastic opening tool, pry the internal case from the external case.
  5. ComNet Ericsson Panther 600P Speaker Replacement, Speaker: 5 단계, 이미지 1/2 ComNet Ericsson Panther 600P Speaker Replacement, Speaker: 5 단계, 이미지 2/2
    • Locate the device's speaker inside the front panel of the exterior case.
    • Locate the display and speaker stabilizer.
    • Lift the stabilizer up from the bottom and pull the stabilizer out of case.
  6. ComNet Ericsson Panther 600P Speaker Replacement: 6 단계, 이미지 1/3 ComNet Ericsson Panther 600P Speaker Replacement: 6 단계, 이미지 2/3 ComNet Ericsson Panther 600P Speaker Replacement: 6 단계, 이미지 3/3
    • Locate the two 3.75mm screws holding the speaker to the exterior case.
    • Using a T15 Torx screwdriver, unscrew the 3.75mm screws.
  7. ComNet Ericsson Panther 600P Speaker Replacement: 7 단계, 이미지 1/2 ComNet Ericsson Panther 600P Speaker Replacement: 7 단계, 이미지 2/2
    • Lift up on the bottom of the speaker to detach the speaker.
    • Pull the speaker out of the case.
결론
Kellan Sells
회원 가입일: 01/13/15
318 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 183
