소개
Speakers will sometimes rupture from extended periods of high volume. Speakers may also malfunction due to old age. Without a speaker, many devices can not be used. This guide helps you replace the speakers for the ComNet Ericsson Panther 600P.
필요한 것
Look for the release button on the back of the radio.
Press the button and pull down on the battery at the same time. The battery will come free.
Using a T15 Torx screwdriver, unscrew the two screws.
Using a plastic opening tool, pry the internal case from the external case.
Locate the device's speaker inside the front panel of the exterior case.
Locate the display and speaker stabilizer.
Lift the stabilizer up from the bottom and pull the stabilizer out of case.
