주요 콘텐츠로 건너뛰기
Comfort Zone CZ6C Fan Blades Replacement
필요한 것
  1. Comfort Zone CZ6C Fan Blades Replacement, Fan Blades: 1 단계, 이미지 1/3 Comfort Zone CZ6C Fan Blades Replacement, Fan Blades: 1 단계, 이미지 2/3 Comfort Zone CZ6C Fan Blades Replacement, Fan Blades: 1 단계, 이미지 3/3
    • The metal cage is kept in place by three plastic tabs on the plastic body. Focus your pulling around these tabs to make the job easier.
    • In order to remove the metal cage, place one hand firmly on the back plastic body and your other hand on the metal cage.
    • Now work your way around the edge of the fan cage and pull it away from the plastic body.
  2. Comfort Zone CZ6C Fan Blades Replacement: 2 단계, 이미지 1/2 Comfort Zone CZ6C Fan Blades Replacement: 2 단계, 이미지 2/2
    • To remove the fan blade, reach behind it and slowly pull it towards you.
    • If the fan blade axle has any hair or dirt, then clean it with a cloth to avoid further fan blade blockage.
    • If you are having difficulty removing the fan blade, then generously apply WD-40 to the fan blade axle.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Samantha Galicinao
회원 가입일: 04/07/15
289 평판
안내서 2개 작성하였습니다
Cal Poly, Team 17-5, Forte Spring 2015 Cal Poly, Team 17-5, Forte Spring 2015 회원
CPSU-FORTE-S15S17G5
4 회원들
안내서 5개 작성하였습니다
댓글 2개
Where does one buy the replacement blades?
Frank Gould - 답글
where does one buy the replacement blades??
Luis Marrero - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 20
전체 시간: 5,830
