주요 콘텐츠로 건너뛰기
Comfort Zone CZ6C Motor Replacement
필요한 것
  1. Comfort Zone CZ6C Motor Replacement, Motor: 1 단계, 이미지 1/3 Comfort Zone CZ6C Motor Replacement, Motor: 1 단계, 이미지 2/3 Comfort Zone CZ6C Motor Replacement, Motor: 1 단계, 이미지 3/3
    • Make sure to unplug the Comfort Zone CZ6C before replacing the motor. This will prevent the risk of electrocution.
    • Unscrew the main housing screw located right above the main switch using a Phillips screwdriver.
    • Then use gentle force to remove the main housing door.
    • Remember to keep track of your screws!
  2. Comfort Zone CZ6C Motor Replacement: 2 단계, 이미지 1/3 Comfort Zone CZ6C Motor Replacement: 2 단계, 이미지 2/3 Comfort Zone CZ6C Motor Replacement: 2 단계, 이미지 3/3
    • Unscrew the two adjacent housing screws to free the motor cage from the housing.
  3. Comfort Zone CZ6C Motor Replacement: 3 단계, 이미지 1/3 Comfort Zone CZ6C Motor Replacement: 3 단계, 이미지 2/3 Comfort Zone CZ6C Motor Replacement: 3 단계, 이미지 3/3
    • Remove the motor cage from the fan housing.
  4. Comfort Zone CZ6C Motor Replacement: 4 단계, 이미지 1/2 Comfort Zone CZ6C Motor Replacement: 4 단계, 이미지 2/2
    • Unscrew the two adjacent motor cage screws to free the motor
  5. Comfort Zone CZ6C Motor Replacement: 5 단계, 이미지 1/3 Comfort Zone CZ6C Motor Replacement: 5 단계, 이미지 2/3 Comfort Zone CZ6C Motor Replacement: 5 단계, 이미지 3/3
    • The motor is now free to be replaced.
    • If the motor will not move out of its now freed state you can use WD-40 to loosen it
결론
다른 5명이 해당 안내서를 완성하였습니다.
Gage Wilson
회원 가입일: 04/08/15
217 평판
안내서 1개 작성함
Cal Poly, Team 17-5, Forte Spring 2015 Cal Poly, Team 17-5, Forte Spring 2015 회원
CPSU-FORTE-S15S17G5
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 23
30일 전: 68
전체 시간: 5,226
