주요 콘텐츠로 건너뛰기
Comment forcer le redémarrage de l'iPhone X
필요한 것
  1. Comment forcer le redémarrage de l'iPhone X, Comment forcer le redémarrage de l'iPhone X: 1 단계, 이미지 1/1
    • Appuyez brièvement sur le bouton d’augmentation du volume (1)
    • Appuyez ensuite brièvement sur le bouton de diminution du volume (2)
    • Il faut vraiment appuyer très brièvement
  2. Comment forcer le redémarrage de l'iPhone X: 2 단계, 이미지 1/1
    • Pour finir, maintenez le bouton latéral enfoncé jusqu’à ce que le logo Apple apparaisse (3)
결승점
다른 126명이 해당 안내서를 완성하였습니다.
[deleted]
949 평판
안내서 12개 작성하였습니다
댓글 13개
You saved my day. My iphoneX did not respond to anything after connect with the itune. I tried to shut down by holding volume up/down + side button but it didn’t work. So I tried your method and it worked!!! Thank you so much
Satit Jan - 답글
This is a temporary solution whenever my iphone gets unresponsive i used this method but after some time it again starts doing same laggy and unresponsive behaviour
Siraj Munir - 답글
good share. thanks.
MelissaR - 답글
What is the other way?
sa sas - 답글
will it delete all data from my iPhone?
_TR0xuu_ - 답글
댓글 쓰기
조회 통계:
24 시간 전: 61
7일 전: 381
30일 전: 1,535
전체 시간: 348,027
