주요 콘텐츠로 건너뛰기
Comment forcer le redémarrage de l'iPhone XR
필요한 것
  1. Comment forcer le redémarrage de l'iPhone XR, Comment forcer le redémarrage de l'iPhone XR: 1 단계, 이미지 1/1
    • Appuyez brièvement sur le bouton d’augmentation du volume (1)
    • Appuyez ensuite brièvement sur le bouton de diminution du volume (2)
    • Il faut vraiment appuyer très brièvement
  2. Comment forcer le redémarrage de l'iPhone XR: 2 단계, 이미지 1/1
    • Pour finir, maintenez le bouton latéral enfoncé jusqu’à ce que le logo Apple apparaisse (3)
결승점
다른 116명이 해당 안내서를 완성하였습니다.
[deleted]
949 평판
안내서 12개 작성하였습니다
댓글 31개
Unfortunately this did not work for me. It’s frozen so badly that I cannot even shut it off.
Larry Lambert - 답글
same happened to me, did not work
rhayribeiro11 - 답글
thanks it actually worked
nani_161 - 답글
What did you finally do to fix your phone
My xr is frozen and nothing is working
Robin Murray - 답글
댓글 쓰기
조회 통계:
24 시간 전: 51
7일 전: 398
30일 전: 2,119
전체 시간: 679,268
