주요 콘텐츠로 건너뛰기
Comment forcer le redémarrage de l'iPhone 8
필요한 것
  1. Comment forcer le redémarrage de l'iPhone 8, Comment forcer le redémarrage de l'iPhone 8: 1 단계, 이미지 1/1
    • appuyez brièvement sur le bouton d’augmentation du volume (1)
    • Appuyez ensuite brièvement sur le bouton de diminution du volume (2)
    • Il faut vraiment appuyer très brièvement
  2. Comment forcer le redémarrage de l'iPhone 8: 2 단계, 이미지 1/1
    • Pour finir, maintenez le bouton latéral enfoncé jusqu’à ce que le logo Apple apparaisse (3)
결승점
다른 37명이 해당 안내서를 완성하였습니다.
[deleted]
1,508 평판
안내서 12개 작성하였습니다
댓글 9개
Very helpfully, thanks!
user7 - 답글
helpfully, thanks!
pat trixia - 답글
All that happens for me is getting the slide to power off..never a reset. About to throw the phone.
Cheri Hogan - 답글
Same as above. Slide to power off and not able to slide. It is frustrating.
nick_nic112 - 답글
I suggest you learn to read. hold power until apple sign appears. you need to keep holding it. not sliding it to switch off.
Gurin Jeimuzu -
댓글 쓰기
조회 통계:
24 시간 전: 14
7일 전: 115
30일 전: 634
전체 시간: 68,107
