소개
Realizar un reinicio forzado no debe eliminar ningún dato, pero puede ser útil si su iPhone X está congelado o necesita solucionar algún problema.
Presione brevemente el botón para aumentar el volumen (1)
Luego presione brevemente el botón para bajar el volumen (2)
Finalmente, mantenga presionado el botón lateral (3) hasta que aparezca el logotipo de Apple y luego suéltelo.
please what do i do when my iphone X shows Up the Itunes Sign and needs to be Reset ….. And please how do i reset it
I’ve been trying to restart my iPhone X since yesterday night… doing it the way I always do (volume up or down and hold side button) and NOTHING. I just came to look for help online and all the same thing. BUT I found your way… and I got my phone back!!!! It was frozen on the same screens, unresponsive. THANK YOU!!!
It didn’t work :(. I’m pressing the button….
how to know what happen with my iPhone X. dark only could not charge. I did not used a week.
Nope... still frozen cycle....
Yay!! Finally found a simple and easy fix!! and it worked
Still pressing didn't show on
Has terminado
Has terminado
다른 126명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 13개
This is a temporary solution whenever my iphone gets unresponsive i used this method but after some time it again starts doing same laggy and unresponsive behaviour
No, it will only reboot the operating system. Your data and settings will persist.
Didn’t work. Now what?
It's not working for me, please anymore ideas?
Apple logo didn't show on screen,just empty battery sign
Face ID has stopped after changing the screen, how to fix
You have to have a machine that puts the old serial number on the new part so the phone recognizes it. It's called "parts pairing" and it's why Apple sucks. I have seen someone do it with an EEPROM reader/writer but I could not find one for purchase so you would need to go to an Apple-authorized repair tech to have your new parts reserialized.
