주요 콘텐츠로 건너뛰기
Comment forcer le redémarrage de l'iPhone XR
필요한 것
  1. Comment forcer le redémarrage de l'iPhone XR, Comment forcer le redémarrage de l'iPhone XR: 1 단계, 이미지 1/1
    • Appuyez brièvement sur le bouton d’augmentation du volume (1)
    • Appuyez ensuite brièvement sur le bouton de diminution du volume (2)
    • Il faut vraiment appuyer très brièvement
    I have tried this several times and all I get is Siri
    Jacqueline Russell - 답글
    Hello,
    please make sure to follow the instructions correctly.
    Quickly press and release the Volume Up button (1).
    Quickly press and release the Volume Down button (2).
    Finally, press and hold the side button (3) until the Apple logo appears, and then release.
    Denis Bonasera -
    I've Followed the steps promptly.. but still nothing happen.. I've been "pressing+ Hold" more than 30min.. Can u help me in this matter
    Aizuddin Arief Amirullah - 답글
  2. Comment forcer le redémarrage de l'iPhone XR: 2 단계, 이미지 1/1
    • Pour finir, maintenez le bouton latéral enfoncé jusqu’à ce que le logo Apple apparaisse (3)
    I have done this over and over and every time I hold the side button all I get is Siri. Why?
    Haley Parlin - 답글
    Same here… frustrated
    Beth Oancea - 답글
    This is not working after several attempts
    Tarine O Connor - 답글
    I can’t even get it to reset!!!!!!!! The volume button lags my phone what a 15 minute waste of my valuable time
    We are Spoons - 답글
    Danke, hat funktioniert!
    Sabine Schattka - 답글
    Worked! Thank you!
    Kelley Barry - 답글
    Every time I try this, I only get Siri when I press the side button??
    Shauna - 답글
    Press the two up and down volume buttons slowly. Then press and hold the lock button for 15-16 seconds. If this does not work tap and slide the manual off button. Wait for phone to turn back on and try this again. I had this happen earlier last year with iOS 13
    Mitch -
    Works every time for me. Just keep forgetting which button is first.
    Maggie Hansard - 답글
    Great! Thank you so much!!!
    anoutsia - 답글
    Please help. I have this issue and nothing works. I’m alone during this crisis and of course I need my phone. Have iPad but not the same. HELP ME PLEASE. My family is 1500 miles away, I’m alone.
    Gay Mavros - 답글
    Hello, please share your problem and we will try to help.
    Provide as much details as possible.
    Denis Bonasera -
    my screen has been stuck on the black screen with the apple logo, i tried this and its still just cycling through turning off and then turning to the black screen with apple logo. it wont actually turn on like its stuck in some loop???
    Rockwell The Great - 답글
    My Photos app was frozen with a blank white screen. After following the instructions and then doing the steps the 5th or 6th time to reset my iPhone, it finally reset. And it worked. Whew!
    Michelle Rouch - 답글
    yes it worked perfectly thank you sir from india
    venkata ramana - 답글
    Please help it didn’t worked, I can reset it and turned it off it has a problem because I can’t enter to my apps either and they don’t work
    Romina Rohde - 답글
    Hold the big side button and one of the volume (either up or down) at the same time to shut off. Same for restart.
    seth ahmed - 답글
    I am updateing the iOS (I think to 14.4). It is “veryfying” since maybe two hours. When I tried the trick from seth ahmed, it triggers an emergency call with a strange alarming sound, but nothing beyond this. HOW CAN I STOP THIS PHONE? Do I have to wait until the battery is down?
    Willi Brammertz - 답글
    Got sire or Alert Trick don’t works! What happends here?
    2410sanni - 답글
    I tried upper volume, lower volume then right button for 25 seconds. Won’t restart or turn on my phone
    kimmie spencer - 답글
    i tried this over and over .it doesnt work on my phone .When my phone dies the battery screen comes on my phone for about 5-10 minutes after that my phone screen is dark even on the charger ,its been like this for 2 days
    Malik Tatem - 답글
    Bonjour comment faire si on réinitialise notre iphone xr et qu'on n'a oublié l'identifiant et le mot de passe qui était sur liphon
    Fodé BA - 답글
    Contacter le support Apple serait la meilleur façon.
    Yvolosaure69 “Yvolosaure69” -
결승점
다른 116명이 해당 안내서를 완성하였습니다.
[deleted]
981 평판
안내서 12개 작성하였습니다
댓글 31개
Unfortunately this did not work for me. It’s frozen so badly that I cannot even shut it off.
Larry Lambert - 답글
same happened to me, did not work
rhayribeiro11 - 답글
thanks it actually worked
nani_161 - 답글
What did you finally do to fix your phone
My xr is frozen and nothing is working
Robin Murray - 답글
Mine didn’t work this phone is garbage I have for 2 days and is not working
jackie e - 답글
It worked for me. Thanks
zipizawo - 답글
Worked for me. Thanks
Ashley Gihlstrom - 답글
This worked :) Thank you so much
vivek sv - 답글
Tap the up and down side buttons real fast then hold down the side button on the right until the phone turns off
joel chinloy - 답글
thanks it worked!!
Emilia -
doesn’t work
felix - 답글
this tip works fine and succes in my ipone. i think this trick only apply if your iphone not entirely frozen or hang. mine cant go to home but still can acces lock screen
dipta dadia - 답글
my phone is hang during update 13.3.1 i try to reboot but cant.. pls help me
thnaks
chetan bairagi - 답글
My phone won’t respond to touch it won’t shutdown it won’t reset and it won’t forceable shutdown how do you fix that!?
Bie 53 - 답글
Worked on 3rd try! Thank you
broniebee - 답글
it did not work at first but i kept trying and it finally shut my phone off . it worked!
Beth Spallone - 답글
Thanks! Worked for me
Vikas Bhat - 답글
Thanks it did work for me.
MITHUN MOHAN - 답글
I have tried the force restart instructions above, but after the phone shuts down and reboots it stays on the apple logo. Don’t know what to do!
jensencorbin - 답글
Did NOT work…what next?
dave gee - 답글
didn’t work either for me…
chanseng.sandra - 답글
it turned off and then turned back on and is stuck on apple logo.
Natalie Zayas-Bazan - 답글
Worked perfectly for me
Edwin - 답글
My phone was slammed down still worked perfectly until the battery died. Tried to charge it started charging then shut off and Apple symbol kept blinking off and on and now it is completely dead. Will force restart help that?
Elroy Smith - 답글
My ipad did that with the Apple logo flashing. It was the battery. It was the first tablet/phone I worked on myself. When I finally tore down my ipad, the battery was blown up. Once I changed it out, it works fine
Kayla Tobin - 답글
Your explanation through pictures is awesome. My frozen XR is now finally working.
Techbeon
tech beon - 답글
Life saver thank you
Jessica Lei - 답글
my phone is completly charged and just wont turn on, i did these and had it on the charger for well over an hour. It just wont turn on.
Isabella Koehler - 답글
rien comme reaction
Adolphe AGANZE - 답글
댓글 쓰기
조회 통계:
24 시간 전: 51
7일 전: 427
30일 전: 2,062
전체 시간: 679,803
