주요 콘텐츠로 건너뛰기
Comment forcer le redémarrage de l'iPhone Xs
필요한 것
  1. Comment forcer le redémarrage de l'iPhone Xs, Comment forcer le redémarrage de l'iPhone Xs: 1 단계, 이미지 1/1
    • Appuyez brièvement sur le bouton d’augmentation du volume (1)
    • Appuyez ensuite brièvement sur le bouton de diminution du volume (2)
    • Il faut vraiment appuyer très brièvement
  2. Comment forcer le redémarrage de l'iPhone Xs: 2 단계, 이미지 1/1
    • Pour finir, maintenez le bouton latéral enfoncé jusqu’à ce que le logo Apple apparaisse (3)
    Thank you so much for such a simplified step by step guide. I was pulling my hair out for 5 hours since the other websites weren’t specific enough on how long to hold down the Volume up and down button.
    Jayman - 답글
결승점
다른 60명이 해당 안내서를 완성하였습니다.
[deleted]
922 평판
안내서 12개 작성하였습니다
댓글 5개
this method of shutdown would not work for me. And I can’t open up setting to go under general to shutdown either
Peggy Biggs - 답글
Intead use 3utool in computer and restart. I used to do it
raju kb - 답글
Worked as it said it would. Thank you
jillfarrell5707 - 답글
pas moyen de redémarrer avec cette méthode… le mac ne reconnait pas l’Iphone XS
clement.dominiquepascal - 답글
i tryed one way fro force start my i phone xs
press up volume botton and relerese and down volume bottle and quicj release and then hold right side button hold longer time but not work out
suhad patel - 답글
댓글 쓰기
조회 통계:
24 시간 전: 26
7일 전: 155
30일 전: 745
전체 시간: 209,391
