소개
Si vous avez oublié votre mot de passe, code PIN ou si vous voulez effacer ou restaurer votre tablette, vous pouvez effectuer une réinitialisation depuis le menu de dépannage.
Attention ! Une réinitialisation efface toutes les données et remet la tablette en configuration d'usine !
Connectez le chargeur.
Sélectionnez "Options d'ergonomie".
Ouvrez le "Clavier visuel".
Pour réassembler votre appareil, veuillez suivre les étapes dans l'ordre inverse.
다른 34명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 25개
thankz for help
Hi, did you know how to fix Windows tablet stuck in boot? It said that “no bootable device found “. Tablet brand and model : Vulcan Journey.
It started after I erase/format the tablet because I forgot the password.
Thanks
Hello. I have a MPMan with Win 10 installed and the touchscreen does not work anymore.
I'm going to install win 8.1 on it .... win 8.1 was out of production. thank you very much
while i am reset final step erase everything touch not in work how to fix?
