주요 콘텐츠로 건너뛰기
Commercial 8 Quart Bowl-Lift Stand Mixer - Bowl-Lift Arm Adjusting Bracket Replacement
필요한 것
    • Before starting ANY repair/disassembly of the mixer, make sure it is fully unplugged from the electrical outlet.
    • If this mixer is being used in a commercial environment, a LOTO tag can be affixed via the hole on one of the prongs on the mains plug to prevent accidental activation.
    • The speed/motor control assembly contains capacitors which can retain their charge for an indefinite amount of time. These capacitors can present a significant and potentially fatal shock hazard.
  1. Commercial 8 Quart Bowl-Lift Stand Mixer - Bowl-Lift Arm Adjusting Bracket Replacement, Remove the Planetary Assembly: 2 단계, 이미지 3개 중 1개 Commercial 8 Quart Bowl-Lift Stand Mixer - Bowl-Lift Arm Adjusting Bracket Replacement, Remove the Planetary Assembly: 2 단계, 이미지 3개 중 2개 Commercial 8 Quart Bowl-Lift Stand Mixer - Bowl-Lift Arm Adjusting Bracket Replacement, Remove the Planetary Assembly: 2 단계, 이미지 3개 중 3개
    • Place a couple dish towels or other soft materials on the base to protect it from any potential impact.
    • Disconnect the planetary from the motor drive shaft by removing the retaining pin (circled in yellow). You can do this with a hammer and either a pin punch or a Torx T15 screwdriver. Simply hammer the punch/screwdriver on the pin until it comes out the other side.
    • If the planetary assembly doesn't fall out, you might have to give it a firm pull straight down to remove it.
  2. Commercial 8 Quart Bowl-Lift Stand Mixer - Bowl-Lift Arm Adjusting Bracket Replacement, Remove the trim band: 3 단계, 이미지 1개 중 1개
    • Using a #2 Philips Screwdriver, remove the screw which holds on the trim band.
    • Remove the trim band.
  3. Commercial 8 Quart Bowl-Lift Stand Mixer - Bowl-Lift Arm Adjusting Bracket Replacement, Remove the motor housing: 4 단계, 이미지 3개 중 1개 Commercial 8 Quart Bowl-Lift Stand Mixer - Bowl-Lift Arm Adjusting Bracket Replacement, Remove the motor housing: 4 단계, 이미지 3개 중 2개 Commercial 8 Quart Bowl-Lift Stand Mixer - Bowl-Lift Arm Adjusting Bracket Replacement, Remove the motor housing: 4 단계, 이미지 3개 중 3개
    • Remove the four screws (circled in yellow, two on each side) using a #2 Philips Screwdriver
    • Remove the motor housing by lifting it straight up.
    • Depending on the generation of your motor it might have a different coloration than the one in the picture (e.g. older models were all silver).
  4. Commercial 8 Quart Bowl-Lift Stand Mixer - Bowl-Lift Arm Adjusting Bracket Replacement, Remove the main planetary gear: 5 단계, 이미지 2개 중 1개 Commercial 8 Quart Bowl-Lift Stand Mixer - Bowl-Lift Arm Adjusting Bracket Replacement, Remove the main planetary gear: 5 단계, 이미지 2개 중 2개
    • Using a #2 Phillips Screwdriver, remove the four screws (circled in yellow).
    • When removing the last screw, make sure to place your hand under the planetary gear as it is heavy and will fall out immediately.
  5. Commercial 8 Quart Bowl-Lift Stand Mixer - Bowl-Lift Arm Adjusting Bracket Replacement, Remove the motor support brackets: 6 단계, 이미지 3개 중 1개 Commercial 8 Quart Bowl-Lift Stand Mixer - Bowl-Lift Arm Adjusting Bracket Replacement, Remove the motor support brackets: 6 단계, 이미지 3개 중 2개 Commercial 8 Quart Bowl-Lift Stand Mixer - Bowl-Lift Arm Adjusting Bracket Replacement, Remove the motor support brackets: 6 단계, 이미지 3개 중 3개
    • There are two motor support brackets: one in front, one back (shown in the first image)
    • Each bracket is attached to the motor by two screws (one on each side).
    • Using a #2 Phillips screwdriver, remove the four screws (circled in yellow in the second and third images) which attach the two motor support brackets.
    • Take care to place your hand under the support bracket when removing the second screw as they will fall out and could damage the finish.
  6. Commercial 8 Quart Bowl-Lift Stand Mixer - Bowl-Lift Arm Adjusting Bracket Replacement, Disconnect the motor power cable: 7 단계, 이미지 2개 중 1개 Commercial 8 Quart Bowl-Lift Stand Mixer - Bowl-Lift Arm Adjusting Bracket Replacement, Disconnect the motor power cable: 7 단계, 이미지 2개 중 2개
    • Disconnect the motor power cable by depressing the locking tab (circled in yellow) while pulling the connector apart.
    • Do not attempt to remove the hall effect sensor, the cord which attaches back by the fan, as it is much more easily removed at a later step.
  7. Commercial 8 Quart Bowl-Lift Stand Mixer - Bowl-Lift Arm Adjusting Bracket Replacement, Remove the motor mounting screws: 8 단계, 이미지 2개 중 1개 Commercial 8 Quart Bowl-Lift Stand Mixer - Bowl-Lift Arm Adjusting Bracket Replacement, Remove the motor mounting screws: 8 단계, 이미지 2개 중 2개
    • Using a #2 Philips screwdriver, remove the four screws (indicated in yellow, two on each side) attaching the powertrain/motor to the mixer body.
    • Take care to support the motor as it is no longer connected to the mixer body and could damage the circuit board underneath
  8. Commercial 8 Quart Bowl-Lift Stand Mixer - Bowl-Lift Arm Adjusting Bracket Replacement, Remove the hall effect sensor and powertrain/motor: 9 단계, 이미지 2개 중 1개 Commercial 8 Quart Bowl-Lift Stand Mixer - Bowl-Lift Arm Adjusting Bracket Replacement, Remove the hall effect sensor and powertrain/motor: 9 단계, 이미지 2개 중 2개
    • Remove the hall effect sensor from its mount by pressing down on the tab indicated in the first image and sliding it out.
    • Now that the powertrain/motor is fully disconnected from the mixer, remove it and place it to the side.
    • Take care to protect the powertrain/motor, especially the plastic fan at the rear, as damage to any part of the motor/powertrain (including said fan) will require replacement of the entire unit.
  9. Commercial 8 Quart Bowl-Lift Stand Mixer - Bowl-Lift Arm Adjusting Bracket Replacement, Remove the speed/motor control assembly: 10 단계, 이미지 3개 중 1개 Commercial 8 Quart Bowl-Lift Stand Mixer - Bowl-Lift Arm Adjusting Bracket Replacement, Remove the speed/motor control assembly: 10 단계, 이미지 3개 중 2개 Commercial 8 Quart Bowl-Lift Stand Mixer - Bowl-Lift Arm Adjusting Bracket Replacement, Remove the speed/motor control assembly: 10 단계, 이미지 3개 중 3개
    • Using a #2 Phillips screwdriver, remove the two screws (circled in yellow in the first image) holding down the speed/motor control assembly.
    • Slide the board over slightly to to allow the black support at the top of the board (circled in blue in the second image) to slide through the notch in the board or remove the support with a #2 Phillips Screwdriver.
    • Flip the board over to access the power connector (circled in green in the third image).
    • Remove the power connector by depressing the tab on the edge of the connector (circled in purple in the third image) and pulling upwards.
    • The speed/motor control assembly can now be removed and placed to the side.
  10. Commercial 8 Quart Bowl-Lift Stand Mixer - Bowl-Lift Arm Adjusting Bracket Replacement, Remove the power cord: 11 단계, 이미지 1개 중 1개
    • Using a #2 Philips screwdriver, remove the screw (circled in yellow) which attaches the ground wire to the mixer body.
    • Remove the power cord by lifting up at the strain relief where it passes into the mixer (circled in blue).
  11. Commercial 8 Quart Bowl-Lift Stand Mixer - Bowl-Lift Arm Adjusting Bracket Replacement, Remove the Bowl-Lift Arm Adjusting Bracket: 12 단계, 이미지 3개 중 1개 Commercial 8 Quart Bowl-Lift Stand Mixer - Bowl-Lift Arm Adjusting Bracket Replacement, Remove the Bowl-Lift Arm Adjusting Bracket: 12 단계, 이미지 3개 중 2개 Commercial 8 Quart Bowl-Lift Stand Mixer - Bowl-Lift Arm Adjusting Bracket Replacement, Remove the Bowl-Lift Arm Adjusting Bracket: 12 단계, 이미지 3개 중 3개
    • Using a #1 Phillips Screwdriver, remove the small screw anchoring the Bowl-Lift Arm Adjusting Bracket to the handle.
    • Slide the handle out from the mixer body, as shown in the second picture. Continue sliding the handle out until the Bowl-Lift Arm Adjusting Bracket comes free.
    • Using needle nose pliers, detach the C-clip holding the Bowl-Lift Arm Adjusting Bracket from the Bowl-Lift Rod (circled in green). Then remove the Bowl-Lift Arm Adjusting Bracket by sliding it off the Bowl-Lift Rod (slide it towards the direction of the handle).
    • To enable a more clear picture of the C-clip, the third image shows the Bowl-Lift Arm Adjusting Bracket and Bowl-Lift Rod removed from the mixer. It does not have to be removed from the mixer to remove the C-Clip.
결론
If you have difficulty accessing the screw hole for the Bowl-Lift Arm Adjusting Bracket, insert the handle fully into position and rotate the handle until the screw hole aligns with the notch in the Bowl-Lift Arm Adjusting Bracket
작성자
1다른 기여자 명과 함께
PedroDaGr8
회원 가입일: 08/12/12
3,059 평판
안내서 15개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 26
전체 시간: 610
