주요 콘텐츠로 건너뛰기
Commodore 64 3AG fuse Replacement
필요한 것
  1. Commodore 64 3AG fuse Replacement, Removing screws: 1 단계, 이미지 3개 중 1개 Commodore 64 3AG fuse Replacement, Removing screws: 1 단계, 이미지 3개 중 2개 Commodore 64 3AG fuse Replacement, Removing screws: 1 단계, 이미지 3개 중 3개
    • 1. Remove three 6.75mm ph2 screw heads from the casing
  2. Commodore 64 3AG fuse Replacement, Opening: 2 단계, 이미지 2개 중 1개 Commodore 64 3AG fuse Replacement, Opening: 2 단계, 이미지 2개 중 2개
    • 2. Split the case of the C64 open by pulling up on the case towards you
    • Do not pull too hard that you break the clips.
  3. Commodore 64 3AG fuse Replacement, Detach Keyboard from motherboard: 3 단계, 이미지 2개 중 1개 Commodore 64 3AG fuse Replacement, Detach Keyboard from motherboard: 3 단계, 이미지 2개 중 2개
    • 1. Detach the multi-colored wire bundles that's connected to the motherboard
    • In this picture, the power indication LED (connected to the black and red wires) is not fastened to the keyboard panel, yours might be different.
  4. Commodore 64 3AG fuse Replacement, Locate 3AG fuse: 4 단계, 이미지 1개 중 1개
    • 2. Find the 3AG fuse located next to the joystick ports and On/Off switch
  5. Commodore 64 3AG fuse Replacement, Removing the 3AG fuse: 5 단계, 이미지 2개 중 1개 Commodore 64 3AG fuse Replacement, Removing the 3AG fuse: 5 단계, 이미지 2개 중 2개
    • 3. Using the ifixit splugger, prop out the 3AG fuse from the clip.
    • * Replace the 3AG fuse by inserting the new fuse and letting it pop into the clip
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Silvanus Clarke
회원 가입일: 09/26/14
677 평판
안내서 5개를 작성함
USF Tampa, Team 13-6, Staggers Fall 2014 USF Tampa, Team 13-6, Staggers Fall 2014 회원
USFT-STAGGERS-F14S13G6
4 회원들
안내서 15개를 작성함
2가이드 댓글
The fuse is 1.5 Amp, not 3
JC Andy - 답글
3AG does NOT mean a fast acting fuse. It could be either fast or slow blow. The 3 means it's 1 1/4 " long, the "A" means it has Axial connections, and the "G" means it's made of glass.
Toon Konings - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 45
지난 30일: 102
전체 시간: 4,432
