주요 콘텐츠로 건너뛰기
Compact Fluorescent Lightbulb CFL Lightbulb Replacement
  1. Compact Fluorescent Lightbulb CFL Lightbulb Replacement, CFL Lightbulb: 1 단계, 이미지 2개 중 1개 Compact Fluorescent Lightbulb CFL Lightbulb Replacement, CFL Lightbulb: 1 단계, 이미지 2개 중 2개
    • Locate the bad bulb and remove it from the socket. This is achieved by grabbing the bulb lightly and rotating counter-clockwise.
    • The bulb may be hot. If so, use gloves, or wait for it to cool.
  2. Compact Fluorescent Lightbulb CFL Lightbulb Replacement: 2 단계, 이미지 1개 중 1개
    • Procure a new lightbulb, either from a hardware store, or wherever it is you keep new ones.
    • Install the new lightbulb into the socket, this time rotating clockwise.
    • Be sure the power to the socket is turned off before you preform this step. Failure to do so my cause injury.
  3. Compact Fluorescent Lightbulb CFL Lightbulb Replacement: 3 단계, 이미지 1개 중 1개
    • Turn the power on to the light socket by means of a switch or knob.
    • Congratulations! You have successfully changed a lightbulb! Reward your efforts by getting a cold beverage of your choice.
결승점
다른 12명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
WiseGeek
회원 가입일: 04/04/11
1,364 평판
안내서 2개를 작성함
1가이드 댓글
You shouldn't unscrew/screw CFL Bulb from its tube because there is a very small risk that it will break (Especially if it has the tubular shape (2U, 3U and 4U)). Try to unscrew/screwing it from its plastic base.
Jokid - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 40
전체 시간: 8,461
