주요 콘텐츠로 건너뛰기
Compaq Evo N1000v Fan Replacement
필요한 것
  1. Compaq Evo N1000v Fan Replacement, LED Cover: 1 단계, 이미지 1/1
    • Flip the laptop over with the rear panel facing forward.
  2. Compaq Evo N1000v Fan Replacement: 2 단계, 이미지 1/1
    • Using a TR8 Torx screwdriver, remove the two T8 Torx screws that secure the LED cover to the base enclosure.
  3. Compaq Evo N1000v Fan Replacement: 3 단계, 이미지 1/1
    • Flip the laptop back over with the front facing forward. Open the screen.
    This step could likely be removed.
    H. Nye - 답글
  4. Compaq Evo N1000v Fan Replacement: 4 단계, 이미지 1/1
    • Locate the F1 and F2 keys near the top left corner of the keyboard.
    This could be where to tell users to flip the computer over and open it if that is deemed necessary.
    H. Nye - 답글
  5. Compaq Evo N1000v Fan Replacement: 5 단계, 이미지 1/1
    • While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  6. Compaq Evo N1000v Fan Replacement: 6 단계, 이미지 1/1
    • Locate the Scroll and Pause keys near the top right corner of the keyboard.
  7. Compaq Evo N1000v Fan Replacement: 7 단계, 이미지 1/1
    • While holding the Scroll and Pause keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  8. Compaq Evo N1000v Fan Replacement: 8 단계, 이미지 1/2 Compaq Evo N1000v Fan Replacement: 8 단계, 이미지 2/2
    • Insert a spudger between the F7 and F8 keys. Lift up to remove the LED cover.
  9. Compaq Evo N1000v Fan Replacement, Keyboard: 9 단계, 이미지 1/1
    • Lift the back edge of the keyboard and pull towards the screen.
  10. Compaq Evo N1000v Fan Replacement: 10 단계, 이미지 1/1
    • Pull the cable and lift up to release.
  11. Compaq Evo N1000v Fan Replacement: 11 단계, 이미지 1/1
    • Remove the keyboard.
  12. Compaq Evo N1000v Fan Replacement, Heat Sink: 12 단계, 이미지 1/1
    • Disconnect the cable connecting the fan to the system board.
  13. Compaq Evo N1000v Fan Replacement: 13 단계, 이미지 1/1
    • Remove the four screws from the heat sink.
  14. Compaq Evo N1000v Fan Replacement: 14 단계, 이미지 1/1
    • Pull the the heat sink up and out of the computer.
  15. Compaq Evo N1000v Fan Replacement, Palm Rest: 15 단계, 이미지 1/1
    • Close the laptop and flip it so the rear panel is facing up.
  16. Compaq Evo N1000v Fan Replacement: 16 단계, 이미지 1/1
    • Using the TR8 Torx screwdriver, remove the six screws from the back case.
  17. Compaq Evo N1000v Fan Replacement: 17 단계, 이미지 1/1
    • Remove the battery.
    • Remove the screw from the metal support on the case edge with a Torx T8 screwdriver.
    • Flip the laptop over again so the top is facing up.
    • Open the laptop screen and face it towards you.
    I suggest adding a step showing how to remove the battery, and how to identify the palm rest for those who need extra help.
    H. Nye - 답글
  18. Compaq Evo N1000v Fan Replacement: 18 단계, 이미지 1/1
    • Lift the the palm rest up from the front edge of the laptop and swing it towards the screen.
    • Be gentle as it is connected by some cables.
    I suggest adding a picture of the palm rest from the top.
    H. Nye - 답글
  19. Compaq Evo N1000v Fan Replacement: 20 단계, 이미지 1/1
    • Disconnect the second ribbon cable.
  20. Compaq Evo N1000v Fan Replacement: 21 단계, 이미지 1/1
    • Remove the palm rest.
  21. Compaq Evo N1000v Fan Replacement, Top Cover: 22 단계, 이미지 1/1
    • Turn the laptop bottom side up.
  22. Compaq Evo N1000v Fan Replacement: 23 단계, 이미지 1/1
    • Remove the two TM 2.5mm x 8.0mm screws that secure the top cover to the base.
  23. Compaq Evo N1000v Fan Replacement: 24 단계, 이미지 1/1
    • Turn the base top side up with the front facing forward.
  24. Compaq Evo N1000v Fan Replacement: 25 단계, 이미지 1/1
    • Remove the three TM 2.5 mm x 5.0 mm screws that secure the top cover to the base.
  25. Compaq Evo N1000v Fan Replacement: 26 단계, 이미지 1/1
    • Lift the top cover straight up about one inch, then slide forward until the microphone cable is exposed.
    • Disconnect the microphone cable from the system board.
  26. Compaq Evo N1000v Fan Replacement: 27 단계, 이미지 1/1
    • Remove the top cover from the base.
  27. Compaq Evo N1000v Fan Replacement, Fan: 28 단계, 이미지 1/1
    • Disconnect the fan cable from the system board.
  28. Compaq Evo N1000v Fan Replacement: 29 단계, 이미지 1/1
    • Remove the fan from the base.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alex Hernandez
회원 가입일: 04/14/10
46 평판
안내서 4개 작성하였습니다
Cal Poly, Team 29-74, Johann Spring 2010 Cal Poly, Team 29-74, Johann Spring 2010 회원
CPSU-JOHANN-S10S29G74
3 회원들
안내서 14개 작성하였습니다
댓글 2개
Remove battery FIRST before you do anything. Then remove all the screws on the back of the computer. The you can go to the front and follow all the steps afterward.
iam765 - 답글
Please DO NOT firmly remove any connectors. Most connectors have locks. In step 20 you can see the two different colors of the connector the bottom is black and the top (the lock) is brown. Each side of the lock sticks out further than the connector. One side at a time pull back on the lock. Connection should come out with no force. to reconnect, seat connection and push lock back in place. If any issues try unlocking and re-seat connection.
iam765 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 20
전체 시간: 5,806
