주요 콘텐츠로 건너뛰기
Compaq Evo N1000v Heat Sink Replacement
필요한 것
  1. Compaq Evo N1000v Heat Sink Replacement, LED Cover: 1 단계, 이미지 1/1
    • Flip the laptop over with the rear panel facing forward.
  2. Compaq Evo N1000v Heat Sink Replacement: 2 단계, 이미지 1/1
    • Using a TR8 Torx screwdriver, remove the two T8 Torx screws that secure the LED cover to the base enclosure.
  3. Compaq Evo N1000v Heat Sink Replacement: 3 단계, 이미지 1/1
    • Flip the laptop back over with the front facing forward. Open the screen.
  4. Compaq Evo N1000v Heat Sink Replacement: 4 단계, 이미지 1/1
    • Locate the F1 and F2 keys near the top left corner of the keyboard.
  5. Compaq Evo N1000v Heat Sink Replacement: 5 단계, 이미지 1/1
    • While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  6. Compaq Evo N1000v Heat Sink Replacement: 6 단계, 이미지 1/1
    • Locate the Scroll and Pause keys near the top right corner of the keyboard.
  7. Compaq Evo N1000v Heat Sink Replacement: 7 단계, 이미지 1/1
    • While holding the Scroll and Pause keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  8. Compaq Evo N1000v Heat Sink Replacement: 8 단계, 이미지 1/2 Compaq Evo N1000v Heat Sink Replacement: 8 단계, 이미지 2/2
    • Insert a spudger between the F7 and F8 keys. Lift up to remove the LED cover.
  9. Compaq Evo N1000v Heat Sink Replacement, Keyboard: 9 단계, 이미지 1/1
    • Lift the back edge of the keyboard and pull towards the screen.
  10. Compaq Evo N1000v Heat Sink Replacement: 10 단계, 이미지 1/1
    • Pull the cable and lift up to release.
  11. Compaq Evo N1000v Heat Sink Replacement: 11 단계, 이미지 1/1
    • Remove the keyboard.
  12. Compaq Evo N1000v Heat Sink Replacement, Heat Sink: 12 단계, 이미지 1/1
    • Disconnect the cable connecting the fan to the system board.
  13. Compaq Evo N1000v Heat Sink Replacement: 13 단계, 이미지 1/1
    • Remove the four screws from the heat sink.
  14. Compaq Evo N1000v Heat Sink Replacement: 14 단계, 이미지 1/1
    • Pull the the heat sink up and out of the computer.
결론
다른 2명이 해당 안내서를 완성하였습니다.
kim
회원 가입일: 04/14/10
59 평판
안내서 3개 작성하였습니다
Cal Poly, Team 29-74, Johann Spring 2010 Cal Poly, Team 29-74, Johann Spring 2010 회원
CPSU-JOHANN-S10S29G74
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 14
전체 시간: 4,028
