주요 콘텐츠로 건너뛰기
Compaq Evo N1000v Keyboard Replacement
필요한 것
  1. Compaq Evo N1000v Keyboard Replacement, LED Cover: 1 단계, 이미지 1개 중 1개
    • Flip the laptop over with the rear panel facing forward.
  2. Compaq Evo N1000v Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Using a TR8 Torx screwdriver, remove the two T8 Torx screws that secure the LED cover to the base enclosure.
  3. Compaq Evo N1000v Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • Flip the laptop back over with the front facing forward. Open the screen.
  4. Compaq Evo N1000v Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Locate the F1 and F2 keys near the top left corner of the keyboard.
  5. Compaq Evo N1000v Keyboard Replacement: 5 단계, 이미지 1개 중 1개
    • While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  6. Compaq Evo N1000v Keyboard Replacement: 6 단계, 이미지 1개 중 1개
    • Locate the Scroll and Pause keys near the top right corner of the keyboard.
  7. Compaq Evo N1000v Keyboard Replacement: 7 단계, 이미지 1개 중 1개
    • While holding the Scroll and Pause keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  8. Compaq Evo N1000v Keyboard Replacement: 8 단계, 이미지 2개 중 1개 Compaq Evo N1000v Keyboard Replacement: 8 단계, 이미지 2개 중 2개
    • Insert a spudger between the F7 and F8 keys. Lift up to remove the LED cover.
  9. Compaq Evo N1000v Keyboard Replacement, Keyboard: 9 단계, 이미지 1개 중 1개
    • Lift the back edge of the keyboard and pull towards the screen.
  10. Compaq Evo N1000v Keyboard Replacement: 10 단계, 이미지 1개 중 1개
    • Pull the cable and lift up to release.
  11. Compaq Evo N1000v Keyboard Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the keyboard.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
kim
회원 가입일: 04/14/10
77 평판
안내서 3개를 작성함
Cal Poly, Team 29-74, Johann Spring 2010 Cal Poly, Team 29-74, Johann Spring 2010 회원
CPSU-JOHANN-S10S29G74
3 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 13
전체 시간: 3,864
